Warning while accessing TM1 objects
Radhika
OLAP Product: IBM Cognos TM1
Version: v9.4.1
Excel Version: Microsoft Excel 2003
Post by Radhika »
I am accessing different TM1 objects (TM1 Architect, TM1 v9.5.1, Windows - 32 bit), but when I click on any TM1 object I get the below warning message.
Warning: "Number of messages sent to the server accedes 100"
I tried to change the port numbers it did not work, even CPU utilization is less when accessing this TM1 server. This happens with all the TM1 servers available on this TM1 admin server.
Any suggestion's resolve this issue.
Radhika
Version: PA 2.0.7
Re: Warning while accessing TM1 objects
Post by jim wood »
Did you enable user messages when completing the install?
Radhika
Version: v9.4.1
Post by Radhika »
Hi Jim,
I haven't noticed any setting related to user messages while installing TM1.
Where can we see this setting and what should be default value.
Radhika
Version: PA 2.0.7
Post by jim wood »
In 9.5.2 you are asked for the messenger port and settings. I always leave this blank. You can check this in the CFG file. Check the operations guide for more details.
