TM1 API Code examples
att
Post by att »
Anybody knows where I can find code samples for TM1 API (9.1.3 Windows 64 bit) - ideally for Visual Basic? I checked documentation and it says:
Sample Code for the TM1 API
We provide sample code for both Visual Basic and C. The samples are located in the TM1 API installation directory.
I could not find this directory at all - not on source CD, not on the server where TM1 is installed. What is exact name of the directory and where should I look for it?
Has anybody tried to connect to TM1 from the SQL Server Integration Services?
Guillaume Galtier
Re: TM1 API Code examples
Post by Guillaume Galtier »
Hi att,
There is some samples into the "TM1 API Guide", provided with the TM1 documentation.
If you don't have this guide with your TM1 documentation, you can download it from the Cognos site.
I hope this helps. ;)
Guillaume
Martin Ryan
Post by Martin Ryan »
att wrote: I could not find this directory at all - not on source CD, not on the server where TM1 is installed. What is exact name of the directory and where should I look for it?
If it's not there then the installer probably choose not to install it for some reason. As Guillaume says you can have a look around on the IBM site, or you can do a re-install and get the samples put on. You could even it do it on another computer, then copy the API examples, then uninstall.
Renaud MARTIAL
Post by Renaud MARTIAL »
you should have some samples located in the '<TM1 installation directory>\API\TM1API\SampleCode\' directory.
In my configuration, I've got code for C++, VB and Java APIs.
Renaud.
att
Post by att »
Renaud MARTIAL wrote:Hello,
Renaud.
I double-checked - there is no such directory on my server. Can it be because we are using 64 bit version?
ScottW
OLAP Product: TM1 CX
Excel Version: 2003 2007
Post by ScottW »
The VB API examples are all really old. For anything in the example set you would be much better off going with TI. But I guess it's a starting point.
API.rar
(58.54 KiB) Downloaded 1017 times
Scott W
Cubewise
www.cubewise.com
