I am working on setting up TM1 workflow using version 9.5 with a Windows OS and am getting an error message after performing the following steps:
1. Select all tasks from the TM1 Workflow toolbar
2. Highlight a particular task
3. Choose the "select" button from pop-up window
4. Error message displays
"Error in CmdSelect_CLick.
91 Object Variable or With Block Variable not set"
5. I select "OK" from the error window
6. Hourglass appears and just runs continuously until I select "close" from the original pop-up window in which I chose the select button.
My co-worker is using Windows XP and does not have this error occuring.
Any help would be greatly appreciated.
Tom
Admin - Moved to the main forum as this is not a bug registered with IBM.
