Web
segunfunwaoluwa
- OLAP Product: cognos tm1
- Version: 9.5.2
Re: Client Access Problem On Websheet
Hello
- Does your TI process do a security refresh statement? / Do you have a rules-based security setup?
- Can you trace in the respective Control Cubes (}... Security) to see what is going on?
- Does it work for a user with "more" privileges?
- ... and so on
- ... and so on
- jim wood
- Version: PA 2.0.7
Also how did you update the security? Did you write straight to the control cube or did you use ElementSecurityPut?
