TM1 Web URL for opening a specific sheet in a Websheet
Martin Ryan
Post by Martin Ryan »
I've had a read of the "Developing Custom Web Applications with the URL API" in developer guide, but can't find any mention of how to write a URL that links to a specific sheet within a websheet.
I want to create a menu on a home page that links to the reports available, not just each workbook, but each sheet within those workbooks.
I don't want to use action buttons if possible as I'd like the home page to be HTML to give me more flexibility with how I build the menu.
Is this possible?
Re: TM1 Web URL for opening a specific sheet in a Websheet
I've used the URL API to build applications and menus navigating to specific views and websheets quite a lot (but not for a while) and recall coming up against the same issue.
The simple solution is to separate any multiple tab reports into single tab worksheets. I've come to regard this as a best practice for designing TM1 web applications anyway, just one of the things to bear in mind from a design perspective if the intended UI is web as opposed to Excel.
tm1ist
OLAP Product: TM1 + BI
Version: 10.2 10.2.2 + 10.2.1 10.2.2
Excel Version: 2010 32 bit
Post by tm1ist »
I have created an enhancement request for this. Please vote if you want this functionality to be added.
http://www.ibm.com/developerworks/rfe/e ... R_ID=73792
