Meaning of .cub$
Posted: Fri Jan 13, 2012 6:56 pm
Can someone help fill me in a little more on why you sometimes get files with $ appended?
Can I safely delete these?
Discussing all things TM1, Planning Analytics, PAx and PAW
https://www.tm1forum.com/
They're generated when you do a data save. The cube in memory is initially saved to the .cub$ file. If the save is successful then the .cub file is replaced by the .cub$ file and the latter is deleted. If the file is still there then either:PlanningDev wrote:Can someone help fill me in a little more on why you sometimes get files with $ appended?
