Dynamic selection of values using parameters
Cognostm1.ibm
Version: 9.5.1 and 9.5.2
Excel Version: 2007 and 2010
Post by Cognostm1.ibm »
I have a scenario where the user wants to dynamically select product type during run time using parameters.
Question: Select Product Type?
Parameters :
Po = Product Type
Type: String
Product Type is dimension.
Product Type values in the dimension are A,B,C,D
And also only the selected product needs to be exported using TI.
Please do the needful....
Shan
Re: Dynamic selection of values using parameters
Cognostm1.ibm wrote:Please do the needful....
Dear Shan,
I think this is a very unrealistic expectation unless you do the needful yourself, starting with reading the request for assistance guidelines and making sure your questions conform to these guidelines. Especially with regards to full description of the issue, version, environment, UI and steps you have already taken to solve the problem.
I suspect that given the extra effort of thinking about an issue before posting you may find in some cases that you can already solve it yourself, AND where this is still not the case it would then be much easier for others to help you.
