Making TM1 Server Available causes error
cdhodge2002
Post by cdhodge2002 »
I am having issues with TM1 Contributor where whenever I make our latest TM1 application available to Contributor to create an application the security on our other 3 tm1 servers for contributors stops working, except for the admin user we designated. I have been working with IBM support but they have been less than helpful. The issue seems to be related to the 4th tm1 server as any combination of the 4th server and the other 3 tm1 servers has the same issue but when the 4th server is shut down everything works. I have checked the ports and there is no conflict there and all the config files are coded to IP address. Any body have any ideas?
Version: PA 2.0.7
Re: Making TM1 Server Available causes error
Post by jim wood »
They are probably being a pain in the backside as you've found a major flaw in their software. They probably never tested it with more than 3 TM1 services.
