Using Excel Reports through TM1web
rossi
Post by rossi »
Trying to view an excel file through the TM1Web and i keep getting the error.
Cannot connect to TM1 Excel Services No connection could be made because the target machine actively refused it
Also can I use a view that has an MDX on it in the excel websheet?
Any ideas please
thanks
Re: Using Excel Reports through TM1web
rossi wrote:Trying to view an excel file through the TM1Web and i keep getting the error.
I'm not at work at the moment so I can't check and confirm, but if memory serves I believe that that message appears when the TM1 Excel Service has stopped running on the server. On the server, check the list of services by right clicking on My Computer and selecting Manage, then go to the Services. Chances are that the TM1 Excel Service won't have "Started" as its status, so just right click on it and start 'er up. It'd be also worthwhile to check the message logs to see whether you can see why the service stopped.
rossi wrote: Also can I use a view that has an MDX on it in the excel websheet?
In what context?
rossi
Post by rossi »
I have a view that has accounts down the left and years across the top
the accounts have an expression attached to them like give me all the N level accounts
rossi wrote:I have a view that has accounts down the left and years across the top
On a websheet? So you're using SubNMs, presumably. I haven't tried it, but I can't think of any reason why that shouldn't work.
