Hi All, and Happy Holidays.
I am on 9.5.2 and created a TI Process to load security to the }ElementSecurity control cubes for about 3 different large account dimensions. The access was simply "write" or none at all. This is so each department/group has access to only the accounts that concern them.
The issue I'm having is that if "}tp_everyone" is not given "write" access, then there is no access to the accounts at all. When I assign "write" access to all of the accounts in }tp_everyone, the accounts now show up and appear are editable, but the group level account security is gone; each group can see all accounts? This defeats the purpose of what I'm trying to do.
I know this is odd, and I have not run into this before. Has anyone run into this?
Thanks in advance,
Christian
Security Issue...}tp_everyone
sander
- OLAP Product: tm1
- Version: 10.2
- Excel Version: 2013
Re: Security Issue...}tp_everyone
I think you are also using Contributor (or Workflow?), and the security you use there is conflicting with TM1 security.
