Crash on a specific server
- Version: 10.2.2 - PA
We have here about 20 instances running on 3 "supposed to be identical" servers. The 20 instances are built the same way (same dimensions, cubes, processes, calculation rules), but correspond to different geographical areas.
Our problem is that we have some instance crashes on one of the 3 servers. If we move the instance to another server, it does not crash anymore.
The crash happens when starting the instance, at the moment "Computing feeders". It is random.
Have you ever met such a situation where an instance crashes on one server and not on another? Any idea ?
Thank you
PS: We use TM1 9.5.2 FP1
Thank you
Re: Crash on a specific server
While it is technically feasible to run multiple instances of TM1 under the same OS session, you do so at your own risk. This is because TM1 does not play well with other apps, even other instances of TM1, when it comes to memory. Each instance of TM1 is going to grab all the memory it needs (or thinks it needs in the case of using multiple processors in the cube loading and processing of feeders). If you have set the MaximumCubeLoadThreads to more than 1 TM1 is going to grab more memory than it actually needs. The more processors you set in this parameter, the more memory it grabs. You could be crashing due to lack of memory caused by the initial garbage memory being too high on startup of the instance. Either Use VMWare, or something like it, to separate the OS sessions, or drop the processors in the MaximumCubeLoadThreads, if you have it set to more than 1.
Thanks for your help but this is not our problem.
First, our server is over-oversized in terms of RAM. Secondly, I manage to make my instance crash even when the others instances are stopped.
- Michel Zijlema
- OLAP Product: TM1, PALO
Hi Catherine,
Is there a process (or image) that guarantees that all three machines are configured identically? Or could there still be minor differences in OS/Drivers/TM1 configuration?
Have you checked the possibilty of a faulty RAM module or other hardware related issue in the problem server?
Michel
Michel
Hi Michel,
The 3 servers have been installed by the same people, at the same moment, but nothing guarantees that everything is exactly the same... I have already checked TM1 version. It's the same. The rest is not under my control.
We have also thought about a problem with RAM, or with the hardware. We are planning to test further in that direction, but not right now because the moment is a little bit critical regarding users activity. Waiting for further investigation, we have parametered the service to restart until it does not crash during the night, as the crash appears only when starting the instance.
Catherine
Catherine
- Michel Zijlema
Hi Catherine,
Just a longshot - and not in line with your remark that the same model works on one server and not on the other, but anyway:
I had a problem once with a server crashing at startup which was due to an ambigious element in a rule (in one of the dimensions of the regarding cube an element was added which name corresponded with an element in another dimension in this cube which was referenced in a rule).
You could start the server without the rule files and add the rules after startup to see whether this will lead to error messages. Maybe this will help you localize the source of the issue.
Michel
Michel
From this statement I assume you've checked in tm1server.log to see the last entry before the crash - is it always the same cube? A crash on this entry would indicate that memory shortage is the issue as setting feeders can use large amounts of memory, but you also mention that:Catherine wrote:The crash happens when starting the instance, at the moment "Computing feeders".
But I'm not clear if you are on 32-bit or 64-bit TM1... I am guessing 64-bit as it is pretty hard to oversize the RAM on a 32-bit server for TM1 nowadays. If you are 32-bit then I would check the setting the 3 gig switch (in the Windows boot.ini file) across all your environments - but this is a real long shot.Catherine wrote:our server is over-oversized in terms of RAM
My only other suggestion at this point is to check the Windows Event log for the tm1sd process and see if that sheds any light on your issue.
Robin Mackenzie
Hi Michel,Michel Zijlema wrote:I had a problem once with a server crashing at startup which was due to an ambigious element in a rule (in one of the dimensions of the regarding cube an element was added which name corresponded with an element in another dimension in this cube which was referenced in a rule).
Was your crash systematic or random?
To be clearer: my crash is random (one crash over 3 or 4 instance start on average), and only one one server.
The rules are OK, it is when adding feeders that the problem randomly appears. I can reproduce the crash when saving the rules.
It seemed to me that it is linked to feeders refering to attributes. But i tried yesterday to rewrite my feeders without refering to those attributes. I reproduced the crash on the 13th start...!
So it's very difficult to determine the source of the crash.
Thank you for your help.
Hi rmackenzie,rmackenzie wrote:From this statement I assume you've checked in tm1server.log to see the last entry before the crash - is it always the same cube? A crash on this entry would indicate that memory shortage is the issue as setting feeders can use large amounts of memory, but you also mention that:But I'm not clear if you are on 32-bit or 64-bit TM1... I am guessing 64-bit as it is pretty hard to oversize the RAM on a 32-bit server for TM1 nowadays. If you are 32-bit then I would check the setting the 3 gig switch (in the Windows boot.ini file) across all your environments - but this is a real long shot.Catherine wrote:our server is over-oversized in terms of RAM
The crash happens when computing feeders for my main cube (only one of the cube has rules in my instance).
We are running 64-bit TM1, and our server has 196 Go RAM...
The event viewer does not help me very much:
"Faulting application name: tm1sd.exe, version: 9.5.20100.18046, time stamp: 0x4e80c6bb
Faulting module name: tm1sd.exe, version: 9.5.20100.18046, time stamp: 0x4e80c6bb
Exception code: 0xc0000005
Fault offset: 0x000000000010fab7
Faulting process id: 0xc5c
Faulting application start time: 0x01ccb36a95e94d11
Faulting application path: C:\Program Files\Cognos\TM1\bin\tm1sd.exe
Faulting module path: C:\Program Files\Cognos\TM1\bin\tm1sd.exe
Report Id: 6b6ee3b1-1f61-11e1-a619-e41f13be6ae8"
It's time to call IBM and get them on the case. They have a special debug version of tm1sd.exe they'll have you run which will capture error information they can use to find out what's happening. I doubt there's anything else that anyone on this forum can do to help you on this one.
I've already done that, but so far, without success. I gave IBM a dump, but they didn't find the problem...tomok wrote:It's time to call IBM and get them on the case.
I posted here just in case somebody met the same problem !
Thank you everybody
One tactic you can use is to remove all the feeders from the rule file and then one by one, add them back to the rule file and restart the instance each time. That way you can identify if one particular statement is causing the server to crash. I've no idea how many feeder statements you have and this could be a very tedious exercise...!Catherine wrote:The crash happens when computing feeders for my main cube (only one of the cube has rules in my instance).
Robin Mackenzie
Is DEP turned off on the crashing server?
There are not so many feeders. So I'v already tested what you say but several feeders statements can cause the crash!rmackenzie wrote:One tactic you can use is to remove all the feeders from the rule file and then one by one, add them back to the rule file and restart the instance each time. That way you can identify if one particular statement is causing the server to crash. I've no idea how many feeder statements you have and this could be a very tedious exercise...!Catherine wrote:The crash happens when computing feeders for my main cube (only one of the cube has rules in my instance).
Their particularity is that they refer to some attributes. So I tried to rewrite my feeders without refering to any attribute. The crash is then less often but is still there!
Once more, we haven't seen any crash on our other servers so I have given up the idea that the crash comes from the TM1 modelisation itself...
Sorry, but what is DEP ?dkleist wrote:Is DEP turned off on the crashing server?
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
Data Execution Prevention - http://en.wikipedia.org/wiki/Data_Execution_Prevention
I don't know. I will ask server team.dkleist wrote:Is DEP turned off on the crashing server?
Do you advise to turn it on if it is not?
Nevertheless, I'm currently moving TM1 instances from the server with crashes to other stable servers. Then we will be free to investigate, reinstall if necessary the server on which we have crashes.
In general, yes. I've experienced enough issues with DEP across different Cognos products that I do that for any of them. The particularly insidious issue with DEP is that it kills processes so symptoms and error messages don't tell you why your application stopped working.
- qml
- Excel Version: 2007 - 2016
I take it that you turn DEP off, not on?dkleist wrote:In general, yes. I've experienced enough issues with DEP across different Cognos products that I do that for any of them.
Kamil Arendt
Yes, turn off DEP ("essential windows services and programs only" option)
