Using TM1api.dll in C#
Posted: Sun Feb 01, 2009 2:19 pm
by argnur
Hi people,
I have a problem with using tm1api.dll in C# application: when I check if the connection to the server was successful TM1ValType(hUser, vServerObject) == TM1ValTypeObject() I always get false(TM1ValType returns TM1ValTypeError). It is kinda urgent, so I will be very grateful if someone helps.
Here is the code:
            TM1APIInitialize();
            int hUser = TM1SystemOpen();
            string st = "COMP"; // the name of the computer
            TM1SystemAdminHostSet(hUser, st);
            int hPool1 = TM1ValPoolCreate(hUser);
            int hPool2 = TM1ValPoolCreate(hUser);
            string sUserName = "admin"; //!!!!! I "start local server" via TM1 Architect and use default names and password
            string sServerName = "local"; //!!!!! Is it OK?
            string sPassword = "";
            int vStringLength = 0; //!!!!! in C++ examples it is given as 10 and in VB as 0
            int vUserName = TM1ValString(hPool1, sUserName, vStringLength);
            int vServerName = TM1ValString(hPool1, sServerName, vStringLength);
            int vPassword = TM1ValString(hPool1, sPassword, vStringLength);
            int vServerObject = TM1SystemServerConnect(hPool1, vServerName, vUserName, vPassword);
            if (TM1ValType(hUser, vServerObject) == TM1ValTypeObject()){
                Console.WriteLine("Success");
            if (TM1ValType(hUser, vServerObject) == TM1ValTypeError()){
                Console.WriteLine("DAMN!!!"); // !!!!! I get this
Here are the API functions' declarations:
        [DllImport(@"tm1api.dll")]
        public static extern void TM1APIInitialize();
        public static extern int TM1SystemOpen();
        public static extern void TM1SystemAdminHostSet(int hUser, [MarshalAs(UnmanagedType.LPStr)]string sAdminHost);
        public static extern int TM1ValPoolCreate(int User);
        public static extern int TM1ValString(int hPool, [MarshalAs(UnmanagedType.LPStr)]string st, int maxSize);
        public static extern int TM1SystemServerConnect(int hPool, int sServerName, int sClientName, int sPassword);
        public static extern int TM1ValType(int hUser, int vServerObject);
        public static extern int TM1ValTypeObject();
        public static extern int TM1ValTypeError();
Please reply if you see my mistakes or if you have sample C# code using tm1api.dll
Thanks in advance!
Re: Using TM1api.dll in C#
Posted: Mon Feb 02, 2009 9:23 am
by Renaud MARTIAL
the TM1SystemServerConnect() function doesn't return a handle to an objet (ie. a TM1 object), but a handle to the server.
Thus, you don't have to check if it's an object.
The only test required is (as you do) to check that it is different of TM1ValTypeError().
If it is different, you can retrieve the Error code and message using TM1ValErrorCode( hUser, vServerObject) and TM1ValErrorString( hUser, vServerObject) functions.
Renaud.
Posted: Tue Feb 03, 2009 12:18 pm
by argnur
Hi Renaud,
Thanks for the reply. TM1ValType(hUser, vServerObject) returns TM1ValTypeError(), so as you suggested I tried to get the error string:
int code = TM1ValErrorCode(hUser, vServerObject);
IntPtr intptr = TM1ValErrorString(hUser, code); // AccessViolationException here
String str = Marshal.PtrToStringAnsi(intptr);
but I get only AccessViolationException. Probably there is a mistake in getting the string error. Can you please help me to fix it?
Posted: Thu Feb 05, 2009 9:58 am
by Renaud MARTIAL
the TM1V for which you ask the string value has to be the one that is of type 'TM1ValTypeError'.
So, the correct code has to be something like this:
if( TM1ValType(hUser, vServerObject) == TM1ValTypeError()){
int nErrCode = TM1ValErrorCode(hUser, vServerObject);
char *szErrMsg = TM1ValErrorString(hUser, vServerObject);
cout << "error " << nErrCode << ":" << szErrMsg;
Renaud.
Posted: Tue Jul 26, 2011 9:23 pm
by B.M. Beltman
Hi People,
I am looking for the full set of API function declarations. All help appreciated!
Bastiaan Beltman
Posted: Tue Jul 26, 2011 9:33 pm
by Alan Kirk
B.M. Beltman wrote: I am looking for the full set of API function declarations. All help appreciated!
Which API? There are three of them. Four, if you count macro functions in Excel.
Since you've posted it in this thread you're presumably referring to the .Net API. Go to the folder in which you installed TM1 (typically C:\Program Files\Cognos\TM1), look in the API folder, then the DOTNETAPIDOC folder. There's a .chm help file there which contains all of the functions.
If you haven't used the .Net API before, be prepared to be in for a helluva disappointment. It will let you read and write values from and to a cube. It will let you do some other rudimentary end user tasks. It will not let you handle most of the metadata functions that administrators need to do. It is, IMHO, a waste of space in its present form.
Posted: Wed Jul 27, 2011 8:50 am
by B.M. Beltman
Let me clarify my question.
I want to use the TM1api.dll in a C# program. For this one needs to declare alle functions in this way:
I would be helped in a great way if someone has the full listing of these function declarations.
I want to be able to to handle metadata functions. This is why I do not want to use the .net API (this is indeed limited, as I found out also) but the tm1API.dll.
Bastiaan
Posted: Wed Jul 27, 2011 9:55 am
by Alan Kirk
B.M. Beltman wrote:Hi,
Bastiaan
I've already logged a gripe with Cognos about the fact that the functions are not fully documented in the TM1 API Manual (which should nonetheless be your first port of call). They may get around to fixing that, some day. In the meantime I suggest that you go to C:\Program Files\Cognos\TM1\API\TM1API and look at the file Tm1api.bas or TM1api.h. Yes, they're VBA / C files respectively, but they do contain most of the function declarations which you should be able to translate to your own language. (Including some which are missing from the manual.) I'd be surprised if anyone has already done that translation for C# though... but you never know, you might get lucky.
Posted: Wed Jul 27, 2011 9:25 pm
by bagovino
Alan Kirk wrote:I'd be surprised if anyone has already done that translation for C# though... but you never know, you might get lucky.
Here you go:
https://github.com/bagovino/TM1ProcessR ... /TM1API.cs
Everything is there except for the functions that deal with the TM1Object struct. Please note that I haven't fully tested every single function and that this comes with the usual this is provided as-is and that you use at your own risk warnings.
Posted: Thu Jul 28, 2011 8:47 am
by B.M. Beltman
Here you go:
Super! Just what I needed. Many, many thanks for sharing this!!!
Bastiaan
Posted: Thu Jul 28, 2011 2:23 pm
by bagovino
You're welcome. :) If you encounter any problems with it let me know; I've only really used the process and chore functions. I also have a translation of it for Python for the extremely curious.
Posted: Wed Aug 10, 2011 4:55 am
by Kyro
Hey, Just though I should share this - in the C# Class you have this:
            [DllImport(TM1APIDLL)]
            public static extern IntPtr TM1ValIndex(IntPtr hUser, int iIndex);
But the original C++ API has this instead:
TM1IMPORT TM1V TM1API TM1ValIndex( TM1P hPool, TM1_INDEX InitIndex );
It will have no effect on how the function runs but if developers feed in a hUser instead of a Value Pool it's not the most fun to debug - I know because I did.
Posted: Mon Aug 15, 2011 2:59 pm
by bagovino
Thanks, I'll fix that. I went into autopilot typing most of that out. :D
Another thing that I discovered that you'll probably want to change is that for every external function declaration that returns a StringBuilder make it return an IntPtr instead. Returning a StringBuilder worked in my 32-bit code, but not when I tried to compile it for 64-bit. Once you do that to get any string value from an IntPtr you would just use Marshal.PtrToStringAnsi(strVal).
For example:
public static extern StringBuilder TM1SystemServerName(IntPtr hUser, int index);
Should be:
public static extern IntPtr TM1SystemServerName(IntPtr hUser, int index);
Here's an usage example:
numServers = TM1API.SystemFunctions.TM1SystemServerNof(userHandle);
for(int count = 1; count <= numServers; count++)
    serverNamePtr = TM1API.SystemFunctions.TM1SystemServerName(userHandle, count);
    serverName = Marshal.PtrToStringAnsi(serverNamePtr);
Posted: Mon Aug 15, 2011 6:36 pm
by DHiggins
bagovino wrote:I also have a translation of it for Python for the extremely curious.
I am interested in the Python translation. Thanks!
