Copy part of a Dimension
ADW
OLAP Product: Cognos Express
Version: 9.5
Post by ADW »
Does anyone know of an easy way to copy part of a dimension to another dimension through TI?
Example being the below. The dimension has multiple alternate hierarchies and I want to create a new dimension made up of just C and its children.
A
--1
--2
--3
B
--1
--3
C
--1
--2
--3
(the numbers are children of the letters)
I have a TI that copies the whole thing but I am struggling to then remove the items I don't want. There may be an easier way?
Re: Copy part of a Dimension
ADW wrote: Does anyone know of an easy way to copy part of a dimension to another dimension through TI?
A
--1
--2
--3
B
--1
--3
C
--1
--2
--3
Use an If block so that the copy is only done if the element is C, or the element passes an ElIspar test where the parent element is C.
If there are intermediate consolidations to be copied between C and the N level elements, use the ElIsAnc function instead of ElIspar.
Skip any elements which don't pass the relevant test.
Be sure that your source is in hierarchy order so that you'll be adding the top level consolidations first, which will then allow you to add the children below that.
Post by David Usherwood »
if(elisanc('dim','C',elem) = 1);
<add to new dim>
endif;
You'll probably want to add C itself as well.
<add to new dim>
endif;
Beat you by 1 minute. :D
Have you looked at the bedrock TI code base? There a a few pre-built processes there that could probably do the job.
ADW
Version: 9.5
Post by ADW »
Thanks for all your replies. I have seen the bedrock site and used some of the code on there. Makes things a lot easier as I get something that works and can then pick it a apart to understand how, rather than sitting here scratching my head.
The elisanc is exactly what I was looking for.
Cheers!
ADW
Version: 9.5
Post by ADW »
Just as a follow up to this for those who may be interested. To get the top level ('C' in the example) I had to put an or (%) in my formula as below.
If( elisanc( pSourceDim, pAncestor, vElement) = 1 % vElement @= pAncestor) ;
pradeep.k.jagadeesan
OLAP Product: IBM Cognos TM1
Version: 9.5.1
Post by pradeep.k.jagadeesan »
Can you post the entire coding for this. I am in need for that. Please.
Thanks in advance.
Pradeep J
Martin Ryan
Post by Martin Ryan »
"Entire coding" is at bedrocktm1.org
Version: 9.5.1
I have checked in BedRock TM1. But unable to find the relevent TI process. Can anybody help me to find the appropriate logic?
Thanks in advance
Pradeep J
pradeep.k.jagadeesan wrote:I have checked in BedRock TM1. But unable to find the relevent TI process. Can anybody help me to find the appropriate logic?
Thanks in advance
Pradeep J
You haven't stipulated what your logic would be to determine how to define the "part" of the dimension which you want to copy. Is it for example
- all descendants from a given consolidation?
- all elements with a given attribute value?
- all elements of a certain level?
- all elements with names starting with a given string?
Assuming it is the first then Bedrock.Dim.Sub.Create.FromConsol.AllElements will contain the logic you need (a simple ElIsAnc test) and you will just need to modify to create a new dimension and copy in the parent child relationships as well as just the element names. The logic for that step you can get from Bedrock.Dim.Clone
