Tm1 Client Silent Install - 9.5.1
Lewis
OLAP Product: Cognos Tm1
Version: 952 FP1 [prod]
Excel Version: 2007 2010
Post by Lewis »
I am attempting to use the silent install for the first time - to upgrade to 9.5.1 clients from 9.1.
Issue install not silent - required normal interaction - here are the parameters I used.
( also install did not enable excel addin or reset adminhost )
setup.exe /S /L1033 /QN INSTALLLEVEL=0 INSTALLDIR="C:\Program Files\Cognos\Tm1" ADDLOCAL=Tm1Client PRODUCTCHOOSEN=TM1P EXCELEDITINCELL=False TM1AUTOLOAD=True TM1LANGSTRING=ENG CLIENTLOGIN=F TM1CLIENTADMHOST=GPIPTCTM1PRD01
Any insight is greatly appreciated .
Re: Tm1 Client Silent Install - 9.5.1
Have you tried IBM support?
Lewis
Post by Lewis »
No not yet- thought I would check with the real experts first to see if someone saw some
"undocumented feature" in my parameters :)
Will be placing a ticket shortly - will update post with information I get back .
qml
Excel Version: 2007 - 2016
Post by qml »
Try this:
setup.exe /S /L1033 /V"/QN INSTALLLEVEL=0 INSTALLDIR="C:\Program Files\Cognos\Tm1" ADDLOCAL=Tm1Client PRODUCTCHOOSEN=TM1P EXCELEDITINCELL=False TM1AUTOLOAD=True TM1LANGSTRING=ENG CLIENTLOGIN=F TM1CLIENTADMHOST=GPIPTCTM1PRD01"
Kamil Arendt
Lewis
Post by Lewis »
Still couldn't get it to work - thanks
Gregor Koch
OLAP Product: Cognos TM1, CX
Version: 9.0 and up
Excel Version: 2007 and up
Post by Gregor Koch »
This one works for 9.5.2
yourpath\setup.exe /s /l1033 /v"INSTALLLEVEL=0 INSTALLDIR=\"C:\program files\Cognos\TM1\" ADDLOCAL=Registry,TM1Client,TM1_OLEDB_Provider,Perspectives,DocLibrary,PDFCamp PRODUCTCHOSEN=TM1P EXCELEDITINCELL=False TM1AUTOLOAD=True EXCELTOOLSVRHOST=yourservername TM1LANGSTRING=ENG CLIENTLOGIN=T TM1CLIENTADMHOST=yourservername /qr /lv* %TEMP%\TM1ClientInstall.log
Lewis
Post by Lewis »
Unfortunately that did not work for me either
Seems to get past first install screen then I get popup > 'upgrade from 9.1 box message.
Ask IBM if there is an install log file output somewhere ( no reply yet ) .
I have ticket in with IBM so far nothing - will post results from ticket
rmackenzie
Post by rmackenzie »
I expect Gregor's command is going to work for a clean install but in your case you want to automate the un-install as well as the install. The silent install commands changed (subtly in some cases) between 9.0.x and 9.1.x and 9.4.x and so I imagine they changed again for 9.5.x. I used to get quick and accurate vendor support on this issue... but haven't asked the question for a while - so good luck!
Robin Mackenzie
