There are some "process" in my TM1 environment. I am new comer but need to modify it. I would like to trace the TM1 loading program, e.g. 1) which process is the first process to how to load dimension data, cube data? 2) how to run the process?
How to trace TM1 loading program
- Steve Rowe
Re: How to trace TM1 loading program
Those will be unique to your system there is no way for us to tell you the answer to that.
You will be able to find the information about which processes are running in the message log of the server.
However, if you don't already know the above then I would highly recommend that you don't attempt to modify any script yourself.
Changing a process can have a massive impact on your system and if how the system works is not documented and your TM1 skills are not at the point where you can't figure your question out for yourself then you should not be attempting any admin level functions.
