Possibility to edit data at consolidation level ?
Posted: Fri Nov 04, 2011 1:29 pm
by pmathur
We have a bit strange requirement from our client :
Data is fed at the month level and consolidate at the quarter level.Now the requirement is like that the user after validating the data can also be able to edit/input the data at the consolidated node(for numeric type data).
I know in string case it will work but in numeric thing it is bit strange and a kind of impossible this. But still is there any way to accomplish this task.
Any help/suggestion would be really appreciated.
Priyank
Re: Possibility to edit data at consolidation level ?
Posted: Fri Nov 04, 2011 1:34 pm
by tomok
Check out the Data Spread functionality. Clients can effectively enter data at a consolidated node and spread back to the months using a number of different spreading techniques.
Posted: Fri Nov 04, 2011 2:46 pm
by qml
Data Spreads are a great and often underused functionality. If your users do not feel comfortable with using them, you might however need to consider building a multi-cube application, where you have cubes providing different levels of granularity (your C level in one dimension/cube is N level in another). Then by cleverly tying the cubes together with rules and/or TI's you can achieve a solution for the antediluvian problem of top-down vs bottom-up planning / data entry.
Posted: Sat Nov 05, 2011 3:55 am
by pmathur
Thanks tomok and qml ..... i will consider your suggestions
Priyank
