Unable to insert more Dependant Sections in Active Form
Posted: Tue Oct 25, 2011 2:55 pm
I;m having trouble building a large active form with many dependant sections. I can create the dependant sections one after the other as described in the manual - but eventually it just stops working - sometimes after a few sections, sometimes after a dozen or so.
The tool creates a new 'TM1RPTVIEW' formula in the proper place with the proper value and a new named range for the report as I specify - but the 'TM1RPTROW' formula returns a blank cell. I tried deleting the TM1RPTVIEW, TM1RPTROW and associated named ranges and inserting the next section again, but still to no avail. Am I doing something wrong?
Or is being able to insert a dependant section luck-based?
