Contributor importing application
ravi.ahuja21
Version: 9.5
Excel Version: 10.0
Post by ravi.ahuja21 »
Hi Friends,
I am moving my contributor application from the development environment to the Live Environment, However when i try to import the contributor application on the Live server using the 'Import Option' it gives me an error.
I have run the “}tp_admin_delete_all” process for the new server that i created.
I am importing with the security and application properties checkbox tick.
I have also tried without the security and properties checkbox ticked.
Application import failed.
Description:
An error occurred while creating cognos 8 objects: cmDuplicateName
Has Any one faced this problem before?
Please help.
csjean
Version: 9.5 9.5.1 9.5.2
Re: Contributor importing application
Post by csjean »
Is your Live Environment's Webserver the same one as was used for development environment?
If it is, you have to delete your original app. You can't install 2 Contributor applications with the same name on the same server.
Hope this helps.
Cheers!
Claude-Sebastien Jean
Senior Consultant in Information Technology
Keyrus Canada
www.keyrus.ca
ravi.ahuja21
Version: 9.5
Excel Version: 10.0
Thanks for the prompt reply,
Yes, The Live Environment's webserver is the same one where i have developed the original application, but the TM1 server are different for both the application.
Sorry, I dint knew this that you can't install 2 Contributor applications with the same name on the same server.Cant i rename the application? Because every time I move
my application from development to live I have to define views and deploy it, I am managing the rights by using the import export of the manage rights options.
Please let me know if there is any work around.
Thanks once again.!
type2sam
Version: 9.5.2
Post by type2sam »
I think this is due to the existing object in the Cognos Content store. Delete the contributor link/object in Cognos Connection and try deploying again.
