Hi experts,
Is there a way to pass a variable value to all the processes in one chore?
I saw one place about the execute process- But I would like to be able to create the chore without having to execute a process from another process.
THanks
Micheline
Pass Variables processes in CHORE
mnasra
- Version: 2.0
- Excel Version: EXCEL 2013
Micheline
Micheline
- Michel Zijlema
- OLAP Product: TM1, PALO
Re: Pass Variables processes in CHORE
You could use global variables for this - see f.i. this post.mnasra wrote:Hi experts,
THanks
Micheline
Or you could setup a variables cube and have the processes in the chore read/write the variable values in this cube.
Michel
mnasra
- Version: 2.0
Merci Michel,
Excellent idea (for your second suggestion!)
The first suggestion (coming from Steve Vincent), I had seen, but I did not know how to apply it.
I am having problems with this:
TI-2 prolog;
asciioutput ( '\\tm1data\out.txt' , NumberToString ( zste_tes_var ) );
BUt I will definitly try your second suggestion.
THANKS a lot
Micheline
TI-2 prolog;
THANKS a lot
Micheline
Micheline
Micheline
