Two Column Dimension Import Circular Ref Error
Posted: Wed Oct 05, 2011 11:00 pm
How should the top node item in a two column (Parent Child) import look? Currently Im trying to copy a dimension from another dimension but im not sure what the parent is for the top node. If I leave it blank I get an error about element not found and if I set it to be the same as the element it gives me a circular reference.
