Security error
viswaraju
OLAP Product: IBM COGNOS TM1
Version: 9.5
Security error
Post by viswaraju »
I have configured locally a data server, i have admin rights to it, but when i tried to open one of the cube...
Is giving an error as
TM1 error:
Key Accounts Manager: has no read access, to elements.
Key accounts manager is a dimension.
In which it has elements Total as consolidated and leaf elements are 1, 2, 3.
Thanks and regards,
TM1 9.5
excel 2007.
Christopher Kernahan
Excel Version: Office 2010
Re: Security error
If you are actually an Admin on the TM1 instance (as opposed to the server) then you would have access to everything. Right-click on the black instance icon in the Server Explorer window - if Security is greyed out, then you aren't logging in with Admin priveleges.
Re: Security error
You can get this message in some releases (I think) when the subset thats saved against the view has no elements in it.
If you right click and select Ascii or text export then you check each of the subsets in the view. That may give you a clue.
Cheers.
