Deleting Log files when i move rule files
Gurumadheshwaran
Version: 9.5.1 and 9.5.2
Post by Gurumadheshwaran »
My project phase has two environments
We do our developments and testing in testing environment and move those files to the production environment
For moving rule files , we need to move the rux and blb file of that cube(if i am not wrong)
While moving those files, i encountered that the changes were not reflected in the production
but i deleted the log folder after moving those files
And then when i start the DB, its got reflected in the production environment
the log folder size was about 7 GB
so is this necessary to delete the log files manually every time or is there any process to delete those log files when we startup the server
Re: Deleting Log files when i move rule files
There is absolutely no correlation between log files and the active models. Log files are exactly what the name implies; a log history of transactions with "history" being the key word. Whether you move them, copy them, delete them, it doesn't matter as it will not affect the current objects. Your observation is merely coincendental.
PlanningDev
Version: 2.0.5
Post by PlanningDev »
I have a similar issue. Copying the RUX file over and then starting the server is not reflecting the rule file changes. Is there anything else we need to be doing?
PlanningDev wrote:I have a similar issue. Copying the RUX file over and then starting the server is not reflecting the rule file changes. Is there anything else we need to be doing?
What about the .blb file, did you copy it is well?
