managing tm1p.ini with two TM1 applications
Posted: Fri Sep 30, 2011 3:42 pm
We currently have some users using a TM1 application under Citrix, with TM1 version 9.4.1.
We are going to implement a new TM1 application, with TM1 version 9.5.2. The access to the new application is done through different Citrix servers. So it is not a problem to have two different versions.
(Target is to have both applications in 9.5.2, but much time is required to do the migration and ensure that everything works fine
Furthermore, we want users from application 1 not to see instances from application 2, and vice versa. Some users are common to both applications, some are not.
Both applications TM1 Perspectives use the same path to TM1P.ini file. But that it is a problem for us, given that we need to specify different admin hosts.
Do you know if it is possible to specify a different path for TM1p.ini to TM1 Perspectives?
Any other idea to solve our problem?
Thank you !
Thank you !
