Tm1 installation error
viswaraju
OLAP Product: IBM COGNOS TM1
Version: 9.5
Post by viswaraju »
help me in this.
Please find the attached.
This is in installation of TM1 9.5
I have even found some data over IBM site.Not able to resolve it.
Thanks and regards
Tm1 9.5
Excel 2007
TM1 installation error1.pdf
(100.7 KiB) Downloaded 256 times
Re: Tm1 installation error
viswaraju wrote:help me in this.
Thanks and regards
Did this include taking a look at page 15 of the installation guide?
If you attempt to install TM1® Web on a system where the Microsoft .NET Framework is not yet installed, the TM1 Web installation will fail if the ASPNET user is not defined on the system.
Error 1609: An error occurred while applying security settings. ASPNET is not a valid user group. This could be a problem with the package, or a problem connecting to a domain controller on the network. Check your network connection and click Retry, or Cancel.
qml
Excel Version: 2007 - 2016
Post by qml »
viswaraju wrote:I have even found some data over IBM site.Not able to resolve it.
Have you tried applying the info you have found or were you hoping that simply browsing the IBM website would solve it?
Which of the following suggestions have you seen and/or applied?
IBM website wrote:If you attempt to install TM1 Web on a system where the Microsoft .NET Framework is not yet installed, the TM1 Web installation will fail if the ASPNET user is not defined on the system.
You must define the ASPNET user before you install TM1 Web.
Edit: Alan beat me to it.
Kamil Arendt
viswaraju
Version: 9.5
Post by viswaraju »
Dear Allan and qml,
thank you.I have solved it
Gregor Koch
OLAP Product: Cognos TM1, CX
Version: 9.0 and up
Excel Version: 2007 and up
Post by Gregor Koch »
Hi viswaraju,
Not that this one is particularly hard to fix but if you do take the time to post that you fixed it, you might as well just let people quickly know how you did it.
Give and take.
