DB function with derived dimension based on an attribute
Posted: Fri Sep 23, 2011 8:31 pm
I have two cubes, one with 6 dimensions and the other with 7 dimensions. 6 dimensions are in common between the two cubes.
I want to bring values from the smaller cube into the larger. The 7th dimension needs to be assigned the value of an attribute in one of the 6 common dimensions.
My feeder in the small cube:
['$000'] => DB('BIGCUBE',!Dim1,!Dim2,!Dim3,!Dim4,!Dim5,!Dim6,ATTRS('Dim6',!Dim6,'ForecastGroup');
My rule in the big cube:
['$000'] = N:DB(...???
I wish I could stay with only one cube and use a hierarchy of Dim6 instead of a 7th dimension. I can't do this, however, because Dim7 will be the approval hierarchy in TM1 Contributor and therefore must have a relatively small number of elements (Dim6 has about 1,000 elements). Btw, I can't just pick a subset of the highest level of a dimension as the approval hierarchy in TM1 Contributor... I get an error saying the children must be included.
Any ideas? Much appreciated!!!
