I've been taking over responsibilities of the previous TM1 developer, so I am new to TM1.
I've been asked by the user to add a new element (?), however I can't see an obvious way to do it. I've tried copying an existing one, then pasting it, that seems to work but then there is not obvious way to rename it.
Anyone know how ?
pls see screenshot attached
adding element, subset editor, TM1 Architect
georgea
- Version: 9.1.2.49
- TM1screen.png (26.74 KiB) Viewed 2827 times
Re: adding element, subset editor, TM1 Architect
You're in the Subset Editor. You need to be in the Dimension Editor. In Server Explorer, right click on the dimension and select "Edit Dimension Structure..."georgea wrote:Hi
Anyone know how ?
georgea
- Version: 9.1.2.49
Thanks, i got it.
