Java Home Strangeness in Cognos 10
Version: PA 2.0.7
Post by jim wood »
Guys,
A bit of a weird one.
I was having trouble connecting a data source so I changed the JAVA_Home variable from C:\installs\java\jdk1.6.0 to C:\installs\java\jdk1.6.0;C:\Program Files\IBM\C10\Bin\jre
It didn't seem to like this so I changed it to C:\installs\java\jdk1.6.0;C:\installs\java\jre\1.6.0
The Congos configuration manager didn't recognise the change. I had to remove the second setting completely.
It doesn't matter if you then go and put the second setting back in it doesn't recognise it. It still reverts to the original error.
I've tried this now with a couple of java homes and I get the same result,
Jim.
dkleist
Re: Java Home Strangeness in Cognos 10
Post by dkleist »
I don't think Java home is a set of libraries like path or classpath: I think it expects to resolve to a single location.
In any event, java home can be problematic for Cognos 10 - if you can avoid it, it's best not to set one at all for C10 servers. (C10 would then use it's own - the calls test for a java_home value and use the cognos install if one is not found).
Version: PA 2.0.7
Post by jim wood »
I'll try removing JAVA_Home as a test. The problem is that I have TM1 Contributor installed on the same box. That uses a seperate instance of Tomcat which needs the java home set. I do wonder if Big Blue tests having the same software on the same environment. If so, not very well.
