Cognos Express 64-bit or 32 bit software?
Posted: Thu Sep 08, 2011 12:54 pm
by RabbitSlava
Hello.
Thank you.
Re: Cognos Express 64-bit or 32 bit software?
Posted: Thu Sep 08, 2011 1:14 pm
by qml
Yes.
Posted: Thu Sep 08, 2011 3:38 pm
by Christopher Kernahan
No.
Posted: Thu Sep 08, 2011 3:51 pm
by jim wood
Could you please read the sticky post that outlines how to ask for help on this forum. If you do not expand the nature of your question one of the admin team will remove it.
Posted: Thu Sep 08, 2011 5:33 pm
by RabbitSlava
Can Cognos Express model be more than 2 GB in memory?
Posted: Thu Sep 08, 2011 5:50 pm
by jim wood
3GB on 32-bit and lots more than that in 64-bit.
Posted: Thu Sep 08, 2011 6:07 pm
by RabbitSlava
64 bit Windows?
or 64 bit Cognos Express?
TM1 to have 2 versions of 32 bit and 64 bit.
We have a distribution Cognos Express. This is a 32 bit app or 64 bit?
Posted: Thu Sep 08, 2011 6:10 pm
by stephen waters
RabbitSlava wrote:Can Cognos Express model be more than 2 GB in memory?
The Cognos Express version that is publicy available will run only on 64 Bit hardware and software. Therefore it can be more than 2Gb in memory if needed.
Posted: Thu Sep 08, 2011 6:13 pm
by qml
RabbitSlava wrote:64 bit Windows?
Both have to be 64 bit versions as you cannot install 64-bit software on 32-bit operating systems.
Que?
My crystal ball is telling me that I don't know. Could be either, most likely 64.
by jim wood
The 32-bit install of Express will run on both windows 32-bit and 64-bit. The 64-bit version will only run on 64-bit. I guess you have to think about your model size. If you think there is a chance that the model use more than 3GB of RAM then go with 64-bit windows and express. If you don't think it will then stick with 32-bit versions of both. Also take hardware in to account. If you server doesn't have more than 4GB of RAM it's not worth going with 32-bit.
I hope that clears things up for you. This has been discussed many times on the forum so if you do a search I'm sure you'll find further info. Also if you contact IBM support I'm sure they'll be more than willing to go through the architecture differences in more detail.
Also check the manuals. There may be further information there,
Posted: Thu Sep 08, 2011 8:19 pm
by RabbitSlava
Ok.
Found on the website IBM 64-bit version of Cognos Express.
IBM Cognos Express 64-bit 9.5.0 Windows Multilingual CZMH5ML
https://www-304.ibm.com/support/docview ... wg24027074
