assignment issue.
ryan
OLAP Product: COGNOS
Version: 9.0
assignment issue.
Post by ryan »
I have a cube1, cube 2.
Cube1 has dim1,dim2,dim3,Measuredim
cube2 has dim1,dimX,dim2,dim3,Measuredim
dim2 has text attribute - 'category', which contains corresponding category of the elements in dim2. dimX is a dimension which holds category as elements. Now I want to source the data(using rule)from cube1 to cube2 such that the category of dim2 matching to the elements of dimX.
dim2:
element(text Attribute-category)
a1(category1)
a2(category1)
a3(category2)
a4(category2)
a5(category2)
a6(category2)
a7(category2)
a8(category3)
a9(category3)
a10(category3)
where as dimX has the following elements:
category1
category2
category3
category4
category5
my intention is (I know this below code will not work)
DB('Cube2',!dim1,ATTRS('dim2',!dim2,'Category'),!dim2,!dim3,'Nvalue')=DB('Cube1',!dim1,!dim2,!dim3,'Nvalue');
Can anyone help me in providing the solution for the above statement.
Thanks in advance.
-Ramesh.
Configuration Details
Microsoft Window Server 2003 Exterprise x64 Edition Service Pack 2
RAM 32 GB
using IBM Cognos Express Xcelerator (Version 10.1)
MS-Office Excel 2010 (12.0.6514.5000)SP2 MSO (12.0.6425.1000)
Microsoft .NET Framework 3.5
Re: assignment issue.
Post by David Usherwood »
Think something like
#Rule, in cube2
[] = n: if(
  attrs('dim2',!dim2,'Category') @= !Dimx,
  DB('Cube1',!dim1,!dim2,!dim3,'Nvalue'),
#else
  0);
# and feeder, in cube 1
[] => DB('Cube2',!dim1,
  'All Categories',
should do it. Won't be a very small feeder though.
