Select by Attribute in the Dimension Editor
Steve Vincent
Version: 10.2.2 FP1
Post by Steve Vincent »
Why O Why O Why is it not possible to select elements by attribute from a dimension using the dimension editor (not the subset one)? I use attributes quite frequently to help debug dimensions (no/multiple parents), especially if the hierarchy is being altered, yet you can't select by attributes when editing the dim. Is there some magical reason why its greyed out, or just an oversight by someone?
Yours,
Disgruntled from Preston, UK ;)
Version: PA 2.0.7
Re: Select by Attribute in the Dimension Editor
Post by jim wood »
It may be something to do with the fact that the attribute is data associated with a element (Stored in a ontrol cube). That would be my guess as to why it is greyed out,
Jim.
Shop at Amazon
