Take Cube from TM1 to Transformer / Powerplay
IBS
Version: 9.5.1
Excel Version: 12.0
Post by IBS »
Hello Community.
I'd like to ask you if and how it is possible to take a cube (with the values from the measure dimension) from TM1 into Transformer (in order to hav a .mdc in Powerplay).
So far we have got some results but they are not satisfying by now. We have successfully loaded all dimensions - except measures - into Framework Manager as datasource package and from there into Transformer.
The measures dimension is specified in TM1. The cube is loaded trough a TI-Process (Turbo Integrator). It's an ODBC which points to an Excel file (.xls).
My TM1 Version: 9.5.1
My Excel Version: 12.0
My OS: Windows Server 2003 32 Bit
My Transformer Version: 8.4.1
Framework Manager is a 8.4.1 too.
We would very much appreciate an answer :)
Thank you very much,
Yannis
PS: If I missed some information please reply.
IBS
Version: 9.5.1
Excel Version: 12.0
Re: Take Cube from TM1 to Transformer / Powerplay
Post by IBS »
We're able to create a Cube in Transformer but the Measures Dimension is not shown.
If we open the cube all values are "na"
dr.nybble
Excel Version: Excel 2007
Post by dr.nybble »
Transformer does not allow you to import fact data from OLAP sources (except SAP BW). This is because efficiently importing fact data from anything other than a very small cube is not viable through the reporting-based query engine. Transformer does have special query support to efficiently extract data from SAP BW.
I would suggest extracting your TM1 cube data to a CSV file and using that as input to Transformer.
Or could you just create the PowerCube in Transformer directly from your Excel file? Transformer supports Excel-based data sources.
