DBSW vs DBS Clearing cells
Posted: Wed Jul 13, 2011 12:47 pm
by Christopher Kernahan
Client is on TM1 9.5.1 accessed through Citrix using Excel 2003.
Have others encountered this?
When a DBS formula references a blank cell and is refreshed, any value in the cube is overwritten with zero.
When a DBSW formula references a blank cell and is refreshed, the value in the cube is not overwritten.
(Admin note: Moved from bugs till proven/SR raised)
Re: DBSW vs DBS Clearing cells
Posted: Wed May 09, 2012 6:43 pm
by sachin
Did you find an answer to this? We have a similar issue in a spreadsheet.
If we use DBS then we get #N/A in all the cells. If we use DBSW, then we can see the numbers in the spreadsheet, but they are not sent to the cube at all. Infact, it wiped out the existing data in the cube!
Thanks.
Posted: Thu May 10, 2012 1:17 am
by Olivier
What is the source for the number you are trying to load through the DBSW formula ?
DBRWs can not be used to source a DBSW.
It is due to the priority in which the formula get calculated.
You can look at this post for more details.
http://www.tm1forum.com/viewtopic.php?f=3&t=3064
Hope this helps,
