I have upgraded my Tm1 version from 9.1 sp3 (64bits) to 9.4MR1 FP3.
Server OS is Windows server 2003 64bits.
I realised our ODBC connections to SQL servers have an issue.
The existing ODBC connections were not modified and are defined using the 64bit interface ( Windows/Syswow64/odbcad.exe )
1 - When i test the ODBC connections (using the same account that is used to run the Tm1 install / runs the tm1 services) throught this interface, i can connect succesfully to my sources.
2 - When i test the ODBC connection (using the same account that is used to run the Tm1 install / runs the tm1 services) throught Excel using external data sources, the configurated ODBC connections appears and enable to issue SQL query to the sources.
3 - When i test the connection (using the same account that is used to run the Tm install / runs the tm1 services) throught Tm1 TI the first instance i had the message "umable to connect to database".
4 - When i try to browse to the existing ODBC datasources, the list is blank ( only a back up exec catalog is in the list).
After investigation, I finnally realised that TI was using the list of ODBC link provided from the 32bits ODBC driver configuration ( Windows/System32/odbcad.exe ).
No ODBC links were configured using 32bits so it explain why the list of ODBC sources for TI was blank.
5 - I tryed to configure to ODBC links in the 32 bit interface in order to test if TI would be able to use that.
I can browse to a source configurated using the 32bits interface but now i get the error "SQL statements fails".
( I suppose this is due to the fact that i am using a 64bit version of Tm1 and therefore should not use 32bits ODBC ).
Note :The Tm1 Log file show the following message :
1280 ERROR 2011-07-11 23:01:49.961 TM1.SQLAPI
E16) Cannot connect to ODBC data source "triprd" IM002[Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified.
08003[Microsoft][ODBC Driver Manager] Connection not open
In my Dev environment the test TM1 server has been installed exactly the same method, refers to ODBC connections 32bits and is able to connect and issue the sql statements.
The windows account used to run and install the test server is different from the account that is used to run our productiono envronment describe above.
I suspected security setting of the account used in Production but i think it that was the case i could not query the SQL servers using excel in the prod server as described above.
Could somebody confirm ( i read the FAQs) that TM1 64bits versions installed on 64bits OS has to use the ODBC set up using the 64bit interface ?
I would like to understand why TM1 did not use the 64 bits set of ODBC connections by default but instead try to get the list from the 32bits interface ?
Also has anybody an idea how to "connect" TI to the ODBC sources defined in the 64bit interface for ODBC connections ?
( Is that the pupose of the new items of Tm1 config file relating to ODBC ?)
Is account security a cause for "SQL Statement failed" ( Account as in Tm1 service account ) ?
Any ideas on how to investigate this further would be appreciated.
