Login to TM1 Web
Posted: Fri Jul 08, 2011 10:28 am
I've installed TM1 9.5.2 on a Windows 2008 64 bits server, and Cognos C10.
Login to TM1 Perspectives and to Cognos is OK (IntegratedSecurityMode is defined to 4).
But I don't manage to login to TM1 Web. I first had the error "The file "portal/variables_TM1.xml" could not be opened".To solve it, I followed IBM procedure:
https://www-304.ibm.com/support/docview ... wg21496610
In the TM1 Web Logon Window, I see only the localhost and tm1server boxes, but there is no login and password boxes (see print screen).
If I press login, I do not have any more the first error message but nothin happens.
Thanks for your help
