I got some troubles when i insert attribute for a dimension with Java API. The java source code and the output as below:
Java source code:
package HMI;
import com.applix.tm1.TM1Attribute;
import com.applix.tm1.TM1Bean;
import com.applix.tm1.TM1Dimension;
import com.applix.tm1.TM1Element;
import com.applix.tm1.TM1ObjectType;
import com.applix.tm1.TM1Server;
import com.applix.tm1.TM1Val;
public class Test {
public static void main(String[] args) {
try {
TM1Bean bean = new TM1Bean();
bean.setAdminHost("MyAdminHost");
TM1Server tm1Server = bean.openConnection1001("tm1serv_sol5_vn",
"jackie_test1", "jackie_test1");
if (!tm1Server.isError()) {
//dimensionCREATE.dimCreate(tm1Server,"jackie_test_dim","C:\\dim.txt");
TM1Dimension dimension = tm1Server.getDimension("jackie_test_dim");
if (!dimension.isError()) {
System.out.println("dimension=" + dimension);
TM1Attribute attribute=dimension.getAttribute("Name");
//TM1Element attribute=dimension.getElement("Name");
insertAttribute(dimension);
if(!attribute.isError()){
System.out.println("attrubute="+attribute);
}else{
System.out.println("###Occured error when getAttribute");
System.out.println("Error message :"+attribute.getErrorMessage());
}else{
System.out.println("###Occured error when getDimension");
System.out.println("###Msg:"+dimension.getErrorMessage());
} else {
System.out.println("###Occured error when open connection");
System.out.println("Error message :"+tm1Server.getErrorMessage());
} catch (Exception e) {
e.printStackTrace();
private static void insertAttribute(TM1Dimension dimension)throws Exception{
System.out.println("Is dimension writable?:"+dimension.isWritable());
System.out.println("Is dimension readable?:"+dimension.isReadable());
TM1Val tv1=dimension.insertAttribute(TM1Attribute.NullAttribute, "jackie_test",TM1ObjectType.AttributeString);
if(dimension.isError()){
System.out.println("***Dimension error:"+dimension.getErrorMessage());
if(tv1.isError()){
System.out.println("***Tv1 error:"+tv1.getErrorMessage());
Output:
dimension=com.applix.tm1.TM1Dimension@a39137
Is dimension writable?:false
Is dimension readable?:true
Error message :ObjectPropertyNotList
I check dimension "jackie_test_dim" after run the above program and found the new attribute "jackie_test" does not insert successfully. It's very urgent . Woule anyone help? Thanks.
How can i insert attribute with Java API?
- tianoklein
- Excel Version: 2013
Re: How can i insert attribute with Java API?
Hi Jackie...
I'm in the same hole...
Did you find the fix?
