Feeder statement at the source cube is crashing the server
Posted: Wed Jun 29, 2011 3:01 pm
Hi All ,
I have a dimension "Investment" which has 80,000 elements in it. I use a feeder statement in a look up cube which feeds data to the main cube. Because of this dimension , the feeder statement is not getting saved. When i put only a consolidation element in the feeder for that dimension, then it is working fine.
I wanted to know whether it will be possible to put a named subset of dimension elements in the feeder instead of !Investment. The main cube will be using only 4,000 elements in the Investement dimension. So I want to put only those 4,000 elements saved as a subset.
Anoop
Anoop
