Concatenation in Rules
anoops81
Version: 9.5.2
Excel Version: Office 2010
Post by anoops81 »
Hi All ,
I wanted to know whether it is possible to concatenate string elements in rules statement.
I wanted to implement a measure element which evaluates to
['Low Index']=['Material']|STR([' Index']);
Here Low Index , Material are string elements and Index is numeric .
I encountered an error "Syntax error on or before STR(['Index']); Missing semicolon
Any other suggestions to implement this will be helpful .
Anoop
Re: Concatenation in Rules
Hi, when referencing strings in rules you need to use the full DB( ....) expression.
You also need the S qualifier
Also I'm not sure that you don't have all the arguments of the STR function in place, it's actually like this STR(number, length, decimal)
['Low Index']= S: DB ('cube' , etc, 'Material') | trim( STR([' Index'], 10 ,0)));
Should give you something like you are after.
anoops81
Version: 9.5.2
Post by anoops81 »
Hi Steve ,
Thanks So much . It is working fine .
