Adding New Dimension To A Cube
cardantim
- Version: 9.5.1
Is it possible to add a new dimension into an existing cube?
Paul Segal
- Version: TM1 11 and up
Re: Adding New Dimension To A Cube
The short answer, I'm afraid, is no. You will need to create a new cube to include the additional dimension. If you have data in the existing cube you can load it to the new cube via TI, and then delete the old cube if required.
Paul
