"25208880","2011-01-02 22:22:08","2011","1","2","22","22","8","_no_user__","0","0","_no_jobtyp","_no_jobsta","BJS_ADM","package.job","BatchJobServer","startNewJobs","DML","DML: Select","SELECT * FROM V_Job_After_Processing ORDER BY JAP_Sort FOR READ ONLY","SELECT * ","---","SELECT * FROM V_Job_After_Processing ORDER BY JAP_Sort FOR READ ONLY","4327","4","327","1","$Revision: 1717 $",Zeile 3 in Eingabedatei MetaData Vorgangszeile (40): Eine zirkuläre Referenz wurde beim Kompilieren der Dimension "TC_Zeit" entdeckt.
"25209260","2011-01-02 23:01:06","2011","1","2","23","1","6","_no_user__","0","0","_no_jobtyp","_no_jobsta","BJS_ADM","package.job","BatchJobServer","startNewJobs","DML","DML: Select","SELECT * FROM V_Job_After_Processing ORDER BY JAP_Sort FOR READ ONLY","SELECT * ","---","SELECT * FROM V_Job_After_Processing ORDER BY JAP_Sort FOR READ ONLY","5445","5","445","1","$Revision: 1717 $",Zeile 39 in Eingabedatei MetaData Vorgangszeile (40): Eine zirkuläre Referenz wurde beim Kompilieren der Dimension "TC_Zeit" entdeckt.
"25209265","2011-01-02 23:02:11","2011","1","2","23","2","11","_no_user__","0","0","_no_jobtyp","_no_jobsta","BJS_ADM","package.job","BatchJobServer","startNewJobs","DML","DML: Select","SELECT * FROM V_Job_After_Processing ORDER BY JAP_Sort FOR READ ONLY","SELECT * ","---","SELECT * FROM V_Job_After_Processing ORDER BY JAP_Sort FOR READ ONLY","4874","4","874","1","$Revision: 1717 $",Zeile 40 in Eingabedatei MetaData Vorgangszeile (40): Eine zirkuläre Referenz wurde beim Kompilieren der Dimension "TC_Zeit" entdeckt.
"25209510","2011-01-02 23:22:40","2011","1","2","23","22","40","_no_user__","0","0","_no_jobtyp","_no_jobsta","BJS_ADM","package.job","BatchJobServer","startNewJobs","DML","DML: Select","SELECT * FROM V_Job_After_Processing ORDER BY JAP_Sort FOR READ ONLY","SELECT * ","---","SELECT * FROM V_Job_After_Processing ORDER BY JAP_Sort FOR READ ONLY","4182","4","182","1","$Revision: 1717 $",Zeile 59 in Eingabedatei MetaData Vorgangszeile (40): Eine zirkuläre Referenz wurde beim Kompilieren der Dimension "TC_Zeit" entdeckt.
"25209515","2011-01-02 23:23:44","2011","1","2","23","23","44","_no_user__","0","0","_no_jobtyp","_no_jobsta","BJS_ADM","package.job","BatchJobServer","startNewJobs","DML","DML: Select","SELECT * FROM V_Job_After_Processing ORDER BY JAP_Sort FOR READ ONLY","SELECT * ","---","SELECT * FROM V_Job_After_Processing ORDER BY JAP_Sort FOR READ ONLY","4203","4","203","1","$Revision: 1717 $",Zeile 60 in Eingabedatei MetaData Vorgangszeile (40): Eine zirkuläre Referenz wurde beim Kompilieren der Dimension "TC_Zeit" entdeckt.
"25209985","2011-01-03 00:00:22","2011","1","3","0","0","22","_no_user__","0","0","_no_jobtyp","_no_jobsta","BJS_ADM","package.job","BatchJobServer","startNewJobs","DML","DML: Select","SELECT * FROM V_Job_After_Processing ORDER BY JAP_Sort FOR READ ONLY","SELECT * ","---","SELECT * FROM V_Job_After_Processing ORDER BY JAP_Sort FOR READ ONLY","4705","4","705","1","$Revision: 1717 $",Zeile 94 in Eingabedatei MetaData Vorgangszeile (40): Eine zirkuläre Referenz wurde beim Kompilieren der Dimension "TC_Zeit" entdeckt.
"25209990","2011-01-03 00:01:30","2011","1","3","0","1","30","_no_user__","0","0","_no_jobtyp","_no_jobsta","BJS_ADM","package.job","BatchJobServer","startNewJobs","DML","DML: Select","SELECT * FROM V_Job_After_Processing ORDER BY JAP_Sort FOR READ ONLY","SELECT * ","---","SELECT * FROM V_Job_After_Processing ORDER BY JAP_Sort FOR READ ONLY","8112","8","112","1","$Revision: 1717 $",Zeile 95 in Eingabedatei MetaData Vorgangszeile (40): Eine zirkuläre Referenz wurde beim Kompilieren der Dimension "TC_Zeit" entdeckt.
"25209995","2011-01-03 00:02:35","2011","1","3","0","2","35","_no_user__","0","0","_no_jobtyp","_no_jobsta","BJS_ADM","package.job","BatchJobServer","startNewJobs","DML","DML: Select","SELECT * FROM V_Job_After_Processing ORDER BY JAP_Sort FOR READ ONLY","SELECT * ","---","SELECT * FROM V_Job_After_Processing ORDER BY JAP_Sort FOR READ ONLY","5203","5","203","1","$Revision: 1717 $",Zeile 96 in Eingabedatei MetaData Vorgangszeile (40): Eine zirkuläre Referenz wurde beim Kompilieren der Dimension "TC_Zeit" entdeckt.
"25210000","2011-01-03 00:03:40","2011","1","3","0","3","40","_no_user__","0","0","_no_jobtyp","_no_jobsta","BJS_ADM","package.job","BatchJobServer","startNewJobs","DML","DML: Select","SELECT * FROM V_Job_After_Processing ORDER BY JAP_Sort FOR READ ONLY","SELECT * ","---","SELECT * FROM V_Job_After_Processing ORDER BY JAP_Sort FOR READ ONLY","5288","5","288","1","$Revision: 1717 $",Zeile 97 in Eingabedatei MetaData Vorgangszeile (40): Eine zirkuläre Referenz wurde beim Kompilieren der Dimension "TC_Zeit" entdeckt.
"25210240","2011-01-03 00:23:04","2011","1","3","0","23","4","_no_user__","0","0","_no_jobtyp","_no_jobsta","BJS_ADM","package.job","BatchJobServer","startNewJobs","DML","DML: Select","SELECT * FROM V_Job_After_Processing ORDER BY JAP_Sort FOR READ ONLY","SELECT * ","---","SELECT * FROM V_Job_After_Processing ORDER BY JAP_Sort FOR READ ONLY","5043","5","43","1","$Revision: 1717 $",Zeile 115 in Eingabedatei MetaData Vorgangszeile (40): Eine zirkuläre Referenz wurde beim Kompilieren der Dimension "TC_Zeit" entdeckt.
This is my errorlog. The data where the errors happen are already included in the errorlog so you get an idea what the data looks like
