how to change language of message log
dan.kelleher
Version: 9.4
Excel Version: 11
Post by dan.kelleher »
Currently displaying in German. I changed the LANG parameter in the tm1s.cfg file and restarted the server but this didn't fix the issue.
I then went into the language folder in the installation directory and changed the .lang files in the DE folder to match those in the EN folder.
Again, no joy.
Anyone got any ideas (I want to avoid a reinstall if possible).
Dan
Re: how to change language of message log
AFAIK, the only way ot change it will be with a re-install. The LANG parameter only controls the TM1 interface, not logging, and there is nothing in the tm1s-log.properties file that controls the langauge of the logging. There is probably a key in the registry of the server that holds this but I have no idea what it is.
dan.kelleher
Version: 9.4
Excel Version: 11
Thanks TOMOK,
I guess it's back to using google translate for the time being!
Dan
Not sure if this will help.
There is a tiny possibility that 009 is French or it has nothing to do with what you are trying to do!
sander
OLAP Product: tm1
Post by sander »
Ran into this problem also. See this link;
http://www-01.ibm.com/support/docview.w ... wg21569351
Haven't found a solution but you can translate the messages with the lng files, look up the message number in your language file and get the english (or other) out of the other one
Regards, Sander
