All,
I have recently come across the attached message when trying to run TM1TOP.
Can anyone help.
Lee
TM1TOP
- LeeTaylor1979
TM1TOP
- TM1TOP error.xls
- (21 KiB) Downloaded 449 times
- Steve Vincent
- Version: 10.2.2 FP1
Re: TM1TOP
Hi Lee,
Message is simple enough. TM1top wasn't distributed (originally at least) with all the required dll files. Just go to your "bin" folder in the TM1 installation on your PC and copy the tm1lib.dll file from there in to the directory top is running from. You might find it's missing some others too, but just copy that one, run top and if it gives you the same message for a different file copy that across as well.
Re: TM1TOP
To avoid DLL complexities, I recommend copying TM1TOP.EXE _to_ the bin directory, then it'll pick up what it needs.
- LeeTaylor1979
Re: TM1TOP
Thanks guys,
This seems to have done the trick.
Lee
Lee
- Steve Vincent
Re: TM1TOP
Yep, perfectly acceptable as long as the IT Gestapo haven't locked down the directoryDavid Usherwood wrote:To avoid DLL complexities, I recommend copying TM1TOP.EXE _to_ the bin directory, then it'll pick up what it needs.
