I have one problem with hiding cubes in contributor.
I have several cubes with the same approval hierarchy. What i would like to do is to hide each of this cube in relation to specific node of approval hierarchy. It would look something like this:
Approval hierarchy:
A
A1
A2
A3
B
B1
C
Under A, A1, A2, A3 user can only see only CUBE 1 , under B, B1 user can only see cube B, and under C user can only see cube C.
This works just fine if you have three different users, but when you have only one user he will see three tabs for three views of those three cubes under each node. Of course i have made views under each cube, with subset for approval hierarchy.
Subset would look like this:
Cube 1
View 3
Subset 1 :
A
A1
A2
A3
Cube 2
View 3
Subset 2:
B
B1
B2
Cube 3
View 3
Subset 3:
C
When you open node A, I get all three tabs A, B, C and of course only under tab A i can see the data (since the approval hierarchy has a subset only for A elements). If i open any of B elements will get the data only under B tab and the same for C.
Is it possible to hide tab based on security on GROUPS , cube security and contributor security?
Thanks!
