ELISANC Worksheet Function
mikegrain
Post by mikegrain »
A quick and dirty example of how it can be done, more a proof of concept than anything else.
But... Maybe somebody will find it useful ;)
Returns a TRUE or FALSE as opposed to the super user friendly 1 or O of the equivalent rules function, could be enhanced in numerous ways and even re-written using the API (though I am not sure how much faster it would be in an interpreted environment like VBA).
Feel free to do with it what you will.
Mike
ELISANC.zip
(9.9 KiB) Downloaded 1157 times
mmatt
Version: TM1 10.2.2, Jedox 6
Excel Version: Excel 2016
Re: ELISANC Worksheet Function
Post by mmatt »
This is a kind piece and works! Where to pay donations? :)
Attila
TJMurphy
Version: PA 2.0.6 Local
Post by TJMurphy »
Sweet, thank you!
Tony
yyi
Post by yyi »
Thank You, and here's some additional vba to list all the parents in between ancestor and descendant:
(so it can paste into subset editor)
Public vDim As String, vAnc As String, vDsc As String, vPar As String, vTree() As String
Sub build_up_single_hierarchy()
  Dim c As Excel.Range, nPar As Integer, i As Integer, r As Integer
  Dim vDepth As Integer
  vDim = "tm1server:Dimension A"
  vAnc = Range("v_Consol").Value
  vDsc = Range("n_Level").Value
  vPar = ""
  vDepth = Run("Ellev", vDim, vAnc)
  Erase vTree
  ReDim vTree(vDepth)
  Set c = ActiveCell
  c.Value = vDsc
  vTree(r) = vDsc
  r = 1
  If ELISANC(vDim, vAnc, vDsc) = False Then Exit Sub
  While vPar <> vAnc
      nPar = Run("elparn", vDim, vDsc)
      Debug.Print "Parent #"; nPar
      For i = 1 To nPar
        vPar = Run("ELPAR", vDim, vDsc, i)
        vPar = Run("DBRA", vDim, vPar, "Alias 1")
        If ELISANC(vDim, vAnc, vPar) Then
            c.Offset(r, 0).Value = vPar   'display as it goes
            vTree(r) = vPar               'store elements
            r = r + 1
            Exit For
        End If
      Next i
      vDsc = vPar   'level up descendant ~not using 2x parent variables
  Wend
  c.Offset(r, 0).Value = vDsc
  vTree(r) = vDsc
  Application.Wait (Now() + TimeSerial(0, 0, 1))        'attempt at dramatic effect
  r = 0
  For i = UBound(vTree) To 0 Step -1
    If vTree(i) <> "" Then
        Debug.Print i; vTree(i)
        c.Offset(r).Value = vTree(i)
        r = r + 1
    End If
  Next
End Sub
Yeon
BariAbdul
Version: PAW 2.0.8
Excel Version: 2019
Post by BariAbdul »
I couldn't see anything except the blank excel sheet.Thanks
yyi
Post by yyi »
Original author's zip attachment is a blank worksheet with "Elisanc()" function written in the module [Alt-F11]
my additional code can be used by substituting/putting in
1. your dimension name
2. your alias
3. a cell name "n_Level" somewhere on the sheet for the descendant
4. a cell name "v_Consol" somewhere on the sheet for the ancestor
then pick a blank cell and run the sub()
it's useful if you have a big hierarchy with many levels and many consolidations in between
hope that helps
Yeon
