REG:TM1 error
Posted: Wed Jun 08, 2011 12:35 pm
Thanks in advance .
Actually my application is using frontend VC++ code written and backend was Applix TM1 9.0 .actually users are login using VC++ window they are login into the application and doing the calculation according to their requirement and even all calculations also done using vc++ only. Once done all calculation and all values is going to sit in TM1 .but one of my user is doing following calculation
• User said that he is using a too long formula on selected component and he got Client(Frond-end VC++ window) crash
Would you thing that is it problem in VC++ or in tm1?.
Note: calculation and all done by using my VC++ code and there is no rules written in my tm1.
As per as I understood that there could be a memory related problem in the TM1 server .am I correct or do u think that is it in VC++ code is not handling by too long formula.?
Could please kindly suggest me ASAP?
Thanks in Advance.
Thanks in advance .
Thanks in Advance.
