Hello Everybody,
I have one problem with tm1web. When i copy one float value from one cell to an other, the comma in float value is replaced by point and i have an error message: repartition failure
Example: when i copy 0,1% in one cell and paste the value in another cell, i have 0.1 rather than 0,1 and i get an error message
How could i fix this problem?
Copy values on tm1Web
moby91
- Version: 9.5.1
- Excel Version: 2003 2007
Re: Copy values on tm1Web
Are you aware that a Copy & Paste of numbers having a comma as a decimal separator can paste an incorrect value in the TM1 Web and TM1 Contributor client ?
See the IBM Technote 1496197:
https://www-304.ibm.com/support/docview ... wg21496197
You wrote that you are using TM1 9.5.1: Did you install any Hotfix for TM1 9.5.1 ?
According to the IBM Technote 1496197 you do experience the Decimal Separator issue after installing one of the Hotfixes from TM1 9.5.1 Hotfix 11 through TM1 9.5.1 Hotfix 15, quote:
"TM1 9.5.1 (affects only interim fix HF11 through HF15)"
Stephane
- Version: 9.5.1
Thank you very much Moby91
I solved my problem with your link!
