Set Min value
BradfordElaine
OLAP Product: COGNOS
Version: 9.0.2
Set Min value
Post by BradfordElaine »
Is there any way to set min value for cell?
kpk
OLAP Product: TM1, CX
Re: Set Min value
Post by kpk »
Have you tried the Validation feature of Excel?
Best Regards,
Peter
Re: Set Min value
BradfordElaine wrote:Hi all,
Peter's given you one way, but you need to be aware that it will only work if the entry mode is Excel. (In addition to which data validation is tissue-paper weak, and can be obliterated by simply pasting a value over the top of the cell which had validation on it.) It won't limit what users can enter directly into the cube via, say, Cube Viewer. (Or even a home-grown DBS formula.)
Within a TM1 cube itself, however, there is no way to limit the value range of an entry into a cell. It's not like an RDBMS where you can put constraints on a field. The only way that you can do it indirectly... and in most cases this isn't worth the effort... is to have two cells, an input cell, and a rules-calculated cell which is used for reporting. In the latter, you could have the rule be (say) If (Input Cell Value <0, 0, Input Cell Value). It would be rare for that to be worth the effort, though.
BradfordElaine
Version: 9.0.2
Re: Set Min value
Thanks for your reply..
Hope in the future, in the newer version, there is a built in function to validate the data..
Sigh.. need to find a reason to push the user to use Excel instead
but thanks everyone! =)
Martin Ryan
Re: Set Min value
Post by Martin Ryan »
There is the picklist option, but it will only work with a discrete set of data (e.g. "1-10", but not "greater than 0"). You also need to be on 9.5.1 (I think) or higher.
If it's of interest take a look in the Developer Guide.
