Simple feeder is not working
kudzis
- OLAP Product: Cognos 8 BI
- Version: 9.5.1
- Excel Version: Excel 2007
My simple feeder is not working, and I don't have any idea why.
Source cube: [Atsargos]
['VISO papildymas'] = n:45;
FEEDERS;
['VISO papildymas'] =>
DB('Pirkimai', !2_DK, !2_Tarnybos_Verslai, !3_Pirkimo būdai, !4 Laikotarpiai, !5 Versijos, 'Planas sub 1');
Target cube: [Pirkimai]
SKIPCHECK;
['Planas sub 1'] = N:
DB('Atsargos', !2_DK, !2_Tarnybos_Verslai, !5 Versijos, !3_Pirkimo būdai, !4 Laikotarpiai, 'VISO papildymas');
In leaf cells I get values '45', but there is no consolidation, and when I comment out SKIPCHECK I can see consolidated values. What could be wrong with my feeder? Dimensions are mapped correctly.
Also (just out of curiosity, not related to my problem), if I write rule SKIPCHECK; ['Planas sub 1'] = N: 1; what intercube feeder should be written to turn on consolidation for this element?
FEEDERS;
SKIPCHECK;
- jim wood
- Version: PA 2.0.7
Re: Simple feeder is not working
For 2 different cubes to feed the contents for each of the dimensions need to be the same (Even if the names are different.) Are you sure that the content of 3_Pirkimo būdai and 5 Versijos is in line?
A feeder must have real data entry somewhere! You cant feed from 'VISO papildymas' because it is derived from a rule that is NOT FED.
(You can feed from a rule calculated value to another rule calculated value and so on but you have to start somewhere with entered "physical" data.)
kudzis
- Version: 9.5.1
Jim,
These are dimensions of my cubes:
Pirkimai: 2_DK, 2_Tarnybos_Verslai, 3_Pirkimo būdai, 4 Laikotarpiai, 5 Versijos, 5 Prognozė
Atsargos: 2_DK, 2_Tarnybos_Verslai, 5 Versijos, 3_Pirkimo būdai, 4 Laikotarpiai, Atsargos
I think DB() are mapped correctly.
lotsaram,
I had no idea that feeders need real data to function. Thank you for this information.
lotsaram,
Then what exactly was it that you thought feeders did?kudzis wrote:I had no idea that feeders need real data to function. Thank you for this information.
kudzis
- Version: 9.5.1
I thought feeders were working on real data and calculated values with no real data. For example, I was sure that ['A'] = N: ['B'] + 15; was very easy to feed; it turns out it's impossible.lotsaram wrote:Then what exactly was it that you thought feeders did?kudzis wrote:I had no idea that feeders need real data to function. Thank you for this information.
Think ['B'] => ['A'] would work quite well
- Michel Zijlema
- OLAP Product: TM1, PALO
Not if ['B'] is zero...David Usherwood wrote:Think ['B'] => ['A'] would work quite well
- Michel Zijlema
The answer is in lotsaram's post: you need to have physical data to feed from.lotsaram wrote:A feeder must have real data entry somewhere! You cant feed from 'VISO papildymas' because it is derived from a rule that is NOT FED.
If your requirement really is that all (!) cells on N: level against ['VISO papildymas'] should get value 45, I would suggest to create a process that loads the 45 number in these cells. If the 45 should be in just a number of cells on N: level against ['VISO papildymas'] (which sounds more logical to me), you should think about whether there is a driver area determining what cells should get the value. Then use this driver area as your feeder.
BTW, IMO hardcoding values in rules (apart from f.i. dividing by 100 in a percentage calculation) is bad practise - I would advise to store these values in a parameter cube.
Michel
@Michel, fair point.
kudzis
- Version: 9.5.1
Michel,
static amount (45) is not in my business logic, i've used it as an example only. Basically, I'll have to create proper feeders in my source cube if I want everything working properly. Since my source cube is small and fast, I was lazy and wanted to use feeders only in target cubes.
