control cube
Posted: Thu May 12, 2011 4:05 am
by viswaraju
hi,
How the control cubes can help us in writing the rules.
In the standard demo in converting the currencies, the rules are written in control cubes, how the elements in the control cubes are connected to our cube created manually.
How the control cubes are going to function?
Thanks and regards
TM1 9.5.1(32-bit)
Excel-2007.
Re: control cube
Posted: Thu May 12, 2011 4:27 am
by Martin Ryan
What do you mean by "the standard demo"? I just had a look at PlanSample and can't see any control cubes that relate to forex.
In any case, control cubes that you create yourself will work like any other cube you create, except that 1) they'll be hidden when control cubes are hidden and 2) you can't delete them via the user interface.
It's generally bad practice to create your own control cubes, except perhaps for really adminy things like controlling email bursting. But I'd usually recommend using security to hide these sort of cubes from people, rather than creating control cubes.
Martin
Re: control cube
Posted: Fri May 13, 2011 6:07 am
by viswaraju
Dear Marrtin,
Standard demo in the sense training from IBM, and control cube was not created manually what i asked? in the training demo there is an situation for currency changing. This control cubes are used.
Thanks and regards.
Re: control cube
Posted: Fri May 13, 2011 8:22 am
by Martin Ryan
For a forex calc? Really? I wouldn't want to say anything negative about our good IBM friends, but using control cubes to hold Forex rates is not what I'd call best practice.
IMHO, the only way that control cubes should be used in a forex calculation is that the currency codes should be stored as attributes against cost centres. Attributes are stored in control cubes - but that is the only way the control cubes should be involved. The rules will reference the attributes via attrs, not via DBs into the control cubes.
Marrtin (moving up from Ryan at least).
Re: control cube
Posted: Fri May 13, 2011 2:36 pm
by tomok
Martin Ryan wrote:IMHO, the only way that control cubes should be used in a forex calculation is that the currency codes should be stored as attributes against cost centres.
Even that would be a bad idea because you wouldn't be able to have any time distintinction to the rates without having a bunch of attributes. I wouldn't put it past IBM though.
Re: control cube
Posted: Sat May 14, 2011 11:22 pm
by Martin Ryan
By currency codes I meant currency codes, e.g. NZD, AUD, USD, GBP and so on.
http://en.wikipedia.org/wiki/ISO_4217,
http://www.currencysystem.com/codes/
