Create attributes
Posted: Wed May 11, 2011 8:32 am
by Apelsin
Hi everyone! I created a process in Turbointergrator, which add new elements and data from source-cube to cube - receiver. Now I want to create attributes in receiver-cube based on the data in element of measures dimension in source-cube in Turbointergrator. Process shows only dimension of cub-source not elements....
Could you please help me?
P.S. I am working in TM1 only one month.
Re: Create attributes
Posted: Wed May 11, 2011 2:02 pm
by ajain86
Use function ATTRINSERT to create a new attribute.
Use function ATTRPUTS or ATTRPUTN to populate the attribute.
Posted: Thu May 12, 2011 3:11 am
by Apelsin
Ankur,
Probably it will be more clear if I add some details: there is source cube - property additions, where the type of the "addition" is indicated (purchases, capital repair, or internal movement) and there is receiver cube, where all PPE data is stored. I 've made a process to add new data (new element) of PPE to receiver cube.
But there is a capital repair that should inserted as a child into existing asset according to the type of the "addition". Addition an element in measures dimension.
But using AttrPutS(Value, DimName, ElName, AttrName)- I can only assign specific value, however I need values of the (Adddition) element in measures dimension. Is there any function in Turbointegrator as DB or vlookup?
Posted: Thu May 12, 2011 4:49 am
by Martin Ryan
I think you might be looking for cellgetn, cellgets, cellputn and cellputs. This is the TI equivalent of Excel's DBRW and DBS.
Posted: Thu May 12, 2011 10:07 am
by Apelsin
I have discovered that these cubes use the same dimension and data of PPE addition is already in receiver cube.
Now I need a formula with following statements:
"If asset is purchased, than it should be added in receiver cube
But if capital repair to the asset is made, than it should be added as subsidiary to the existing element"
I am confused with writing if statements in TI
Posted: Thu May 12, 2011 8:57 pm
by Martin Ryan
You don't mention if you've already consulted the help files? They explain the two types of if statement. Use the Reference Guide.
