Has anyone experienced issues with TM1 not recognizing new security groups? I have ensured that the new group is assigned the proper ApplicationSecurity, CubeSecurity, DimensionSecurity and the relevant ElementSecurity (for department and version controls). I then assigned a test user ID to the new group and attempted login through TM1web and got the following error message: “Login Failed. Please Try Again…You (sic) does not belong to any groupâ€.
What's interesting is that when I add an existing security group to the test user ID and attempted login, it works fine and I can access all the departments assigned to the existing and the new groups.
What do I need to do to refresh the system so that it will recognize the new group? I had not had this problem before as I had always been able to add new departments and new security group assignments. Does anyone have any suggestions why this issue would surface all of a sudden.
Thanks!
Re: TM1 not recognizing new security group
I suggest checking your tm1s.cfg file. There's a parameter in there named GroupsCreationLimit. By default, you can create only 20 groups per session. You may need to increase the number using that parameter if you've run out of security groups.NHuser wrote:Hi,
You may want to check the documentation for further details of the parameter.
- Steve Vincent
- Version: 10.2.2 FP1
Have you tried a security refresh (right click server name / security / refresh security )?
